20 years agoFundamental difference with certain Avalon Signals
Does anyone know what is the fundamental difference between the "chipselect" signal and the "begintransfer" signal? To me it looks very similar, however I cannot seem to find any characteristic...
20 years agoRead this document
http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) But to answer your question ... Chipselect is enabled any time that the avalon bus is actively talking to your component (or from your component if it's a master). Begintransfer is only active at the beginning of a transfer. You would likely only use this if your custom user logic allowed burst transfers which it probably does not. Also, I don't even know if the instruction and data master ports on the NIOS processor support this signal. However, the DMA module does.
