20 years agoFunction socket( ) NIOS II IDE
Hi all, I am trying to implement a UDP-server on my NIOS II dev kit. In order to create a UDP-server I am trying to implement the function socket( ) to establish a connection. But I don't k...
20 years ago --- Quote Start --- --- Quote Start --- Are you using the standalone LWIP port for the Altera HAL? If so, the better thing you can do is to modify the example that is distributed together with the LWIP port... (Note that you have to use the raw API, not the socket API... there is a text file inside the demo) bye PJ <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10723)</div> --- Quote End --- Hi PJ, I tried to run the LWIP Web Server but the compiler is complaining about missing several .h-files. But when I browse through the directory they are there. I never worked with this IDE before, so can you tell me how to include files or paths with this IDE!? Cheers, Danny
