20 years agoFunction socket( ) NIOS II IDE
Hi all, I am trying to implement a UDP-server on my NIOS II dev kit. In order to create a UDP-server I am trying to implement the function socket( ) to establish a connection. But I don't k...
20 years ago --- Quote Start --- originally posted by paolo.gai@Nov 1 2005, 09:33 AM are you using the standalone lwip port for the altera hal? if so, the better thing you can do is to modify the example that is distributed together with the lwip port... (note that you have to use the raw api, not the socket api... there is a text file inside the demo)
bye
pj
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10723)
--- quote end ---
--- Quote End --- Hi PJ, which example are you refering to!? Do you mean the LWIP Webserver?! So you say raw API is faster then the socket API?! Cheers, Danny
