21 years agoftpd problem
Hi all, I'm using the Microtronix uClinux 2.6.5-uc0 release and the original ftpd distributed with it. I can connect & login ok ... but I'm unable to open a data connection. I ...
21 years agook, I solved:
when u try to connect to ftpd server in dev. board just use as the user name "root" instead of "nios" and password remains the same "uClinux". Then u will get rw ftp access to /var and /tmp dirs... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif I know, it is the only temporary solution, but it works even without any intervention to filesystem configuration..
