FTP Server Can't List File
Hi, All!
The FTP server in the uClinux of our Nios II platform has worked successfully. But when I use the FlashFXP ftp client to list the exist file in the ftp server, I can't see anything. In actually, there are some files in the FTP server. If I access the FTP server in the MS-DOS mode, everything is OK! Could anybody tell me WHY!!!5 Replies
May i know how you access it in ms-dos prompt?
i keep getting this error no matter wat i input. Pls advise. Thx!C:\Documents and Settings\JWLAM>ftp 192.168.1.12 Connected to 192.168.1.12. 220- Welcome to the uClinux ftpd! 220 uClinux FTP server (GNU inetutils 1.4.1) ready. User (192.168.1.12:(none)): ftp 500 'USER ftp': command not understood. Login failed. ftp> quit 500 'USER ftp': command not understood. C:\Documents and Settings\JWLAM>- Msg06484
I got the iniche to work with the ucossi.
I am trying to start the FTP server.
I get strange answers such as
PS C:\Users\123> ftp 192.168.xxx.xxx
Connected to 192.168.xxx.xxx.
220 Service ready
500 Unsupported command
User (192.168.xxx.xxx:(none)): guest
Connection closed by remote host.
220 Service ready
User (192.168.xxx.xxx:(none)): anonymous
I am not sure why it is doing that.
I do not have any sample code to get this to work.
Essentially I figured out how to get the FTP_SERVER preprocessor define into the bsp, then added a call to ftps_init();
There may be more I need to do.
Any suggestions would help thanks.
Martin
--- Quote Start --- originally posted by jwlam@Mar 2 2007, 12:06 AM may i know how you access it in ms-dos prompt?c:\documents and settings\jwlam>ftp 192.168.1.12 connected to 192.168.1.12. 220- welcome to the uclinux ftpd! 220 uclinux ftp server (gnu inetutils 1.4.1) ready. user (192.168.1.12:(none)): ftp 500 'user ftp': command not understood. login failed. ftp> quit 500 'user ftp': command not understood. c:\documents and settings\jwlam>i keep getting this error no matter wat i input. pls advise.
thx!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21955)</div> --- Quote End --- In MS-DOS mode: ftp 192.168.0.192 Connected to 192.168.0.192. 220- Welcome to the uClinux ftpd! 220 uClinux FTP server (GNU inetutils 1.4.1) ready. User (192.168.0.192:(none)): anonymous 331 Guest login ok, type your name as password. Password: 230 Guest login ok, access restrictions apply. ftp> ls 200 PORT command sucessful. 550 No files found. ftp> quit 221 Goodbye.
i keep getting the 'command not understood' error. mind to help me check if my settings below are correct?ftp 192.168.1.12 Connected to 192.168.1.12. 220- Welcome to the uClinux ftpd! 220 uClinux FTP server (GNU inetutils 1.4.1) ready. User (192.168.1.12:(none)): anonymous 500 'USER anonymous': command not understood. Login failed. ftp> quit 500 'USER anonymous': command not understood.
Thx!/> netstat -a Active Internet connections (servers and established) Proto Recv-Q Send-Q Local Address Foreign Address State tcp 0 0 *:http *:* LISTEN tcp 0 0 *:ftp *:* LISTEN tcp 0 0 *:telnet *:* LISTEN Active UNIX domain sockets (servers and established) Proto RefCnt Flags Type State I-Node Path /> cat /etc/group root:x:0: ftp:x:50: /> cat /etc/passwd root:x:0:0:root:/:/bin/sh ftp:x:14:50:FTP User:/home/ftp: /> - Altera_Forum
hi ganssle,
i can login to the ftp server now. but i also cant list files. have u found any solution to that? Regards
