21 years agoftp and httpd permission
Hi all ! I'm using Cyclone 1c12 eval, NIOS IDE 5.0, Microtronix uClinux kit 1.4. I have an image on uClinux and want to get it back ( download ) to MS Windows. I perform it via the de...
21 years agoHi OneNet,
I'm assuming you're using boa ... first check /etc/config/boa.conf ... the DocumentRoot directive specifies the root directory for your files. > Added : ../../var/1.bmp (we expect the path is "/var/1.bmp") Relative path references that begin with ".." are generally a bad idea since there are some parsing rules that can be confusing. > but when I browse it , the path of the image is "http://192.168.1.3/var/1.bmp" (incorrect) !!! Actually, the URL is correct ... it's just not what you expected or want. Basically, the leading "../" are removed (sometimes referred to as "removing dot segments"). > It means that when the page is browsed , the default folder is "home" and depeding on > which protocol (either ftp or http) it will "look at" the appropriate folder. Yep, but you can make them the same if you want by changing DocumentRoot in the conf file. > How can I get the correct path of the image (1.bmp) ? Try using a softlink to the image file in your document root directory (I believe boa will blindly follow a softlink) then get rid to the blasted "../.." and just use a simple relative path to the softlink like: link_to_img.bmp Regards, --Scott
