19 years agoframe buffer
Hello hippo and all NiosII users! I compiled uClinux-dist with frame buffer (as wrote on nioswiki) and loaded it in my custom board(flash,sdram,vga_controller,uart,eth). Linux is loaded(I see it ...
19 years agoDo you see this message in booting?
fb0: Altera frame buffer device, using 600K of video memory The framebuffer driver is, linux-2.6.x/arch/nios2nommu/drivers/altfb.c You may look at altfb_probe(), which init the hardware. You may need to use scope or signal-tap to check the output pins of the vga controller, HS,VS, etc. You may need to modify the vga component to meet your LCD timing.
