19 years agoframe buffer error part2
After the zImage has been generated, I boot up uClinux but I am unable to run: nano-X & nxterm & and the rest of them...the nio-terminal says bad command or filename I have followed the...
19 years ago --- Quote Start --- originally posted by nick@Apr 6 2007, 02:08 PM i see message fb0: altera frame buffer device, using 600k of video memory.
but when i wrote nano-x & in sdk shell it return [20]. what it means? --- Quote End --- It is running as process number 20. It should be OK. You can check the VGA screen. There should be an arrow cursor on the screeen. If you have mouse, you should be able to move the cursor. <div class='quotetop'>QUOTE </div> --- Quote Start --- Also I found some distinction in menuconfig. on my PC: Device Drivers --> Character devices ---> --- Virtual terminal [ ] Support for console on virtual terminal ... But on nioswiki Device Drivers --> Character devices ---> [*] Virtual terminal [ ] Support for console on virtual terminal so I can't select virtual terminal in my menucongif. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22862) --- Quote End --- [/b] --- Quote End --- It is OK. It is already selected.
