19 years agoframe buffer error part2
After the zImage has been generated, I boot up uClinux but I am unable to run: nano-X & nxterm & and the rest of them...the nio-terminal says bad command or filename I have followed the...
19 years ago --- Quote Start --- originally posted by hippo@Apr 6 2007, 12:08 AM i didn't check the .tar.gz, but it should be the same.
did you apply the nios2 patch once?
can you find uclinux-dist/lib/libjpeg ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22861)
--- quote end ---
--- Quote End --- I check that there is uClinux-dist/lib/libjpeg. nios2 patch once?you mean the uClinux-dist-20070130-nios2-02.diff.gz? I apply that once!
