19 years agoframe buffer error part2
After the zImage has been generated, I boot up uClinux but I am unable to run: nano-X & nxterm & and the rest of them...the nio-terminal says bad command or filename I have followed the...
19 years agoI didn't check the .tar.gz, but it should be the same.
Did you apply the nios2 patch once? Can you find uClinux-dist/lib/libjpeg ?
