19 years agoframe buffer error part2
After the zImage has been generated, I boot up uClinux but I am unable to run: nano-X & nxterm & and the rest of them...the nio-terminal says bad command or filename I have followed the...
19 years ago --- Quote Start --- originally posted by hippo@Apr 5 2007, 04:47 AM you need to select libjpeg,
6. in uclinux-dist user config,
library configuration-->
[*] build libz
[*] build libjpeg
the content of .tar.gz is the same as .tar.bz2 .
just use, tar zxf xxxx.tar.gz
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22836)
--- quote end ---
--- Quote End --- I belive i choose these: Library Configuration--> [*] Build libZ [*] Build libjpeg But the error is also the same! I use tar xvzf xxxx.tar.gz,is it OK?
