19 years agoframe buffer error part2
After the zImage has been generated, I boot up uClinux but I am unable to run: nano-X & nxterm & and the rest of them...the nio-terminal says bad command or filename I have followed the...
19 years agoYou need to select libjpeg,
6. in uClinux-dist user config, Library Configuration--> [*] Build libZ [*] Build libjpeg the content of .tar.gz is the same as .tar.bz2 . Just use, tar zxf xxxx.tar.gz
