19 years agoframe buffer error part2
After the zImage has been generated, I boot up uClinux but I am unable to run: nano-X & nxterm & and the rest of them...the nio-terminal says bad command or filename I have followed the...
19 years ago --- Quote Start --- originally posted by hippo@Apr 4 2007, 02:04 AM i ran through the build again. it works without problem.
i think your source may have problem in patch.
try remove all source and build again.
i include a image of my test in the wiki, and you may try out with the sof in de2_vga.zip.
http://nioswiki.jot.com/wikihome/operating.../zimage_de2_vga (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/framebuffer/zimage_de2_vga)
nano-x &
nxview /home/ftp/rhino.jpg &
the 8m memory on de2 is very tight. so you should [not] add too many features/drivers in kernel , and user apps.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22785)
--- quote end ---
--- Quote End --- I try out with the sof in de2_vga.zip and the zImage_de2_vga in your test,but these happen: I run this command: />nano-x & then,this occur: nano-x:Bad command or filename [25] /> sh 19:child 25 died Could you list the whole information after you run this command?
