19 years agoframe buffer error part2
After the zImage has been generated, I boot up uClinux but I am unable to run: nano-X & nxterm & and the rest of them...the nio-terminal says bad command or filename I have followed the...
19 years agoI ran through the build again. It works without problem.
I think your source may have problem in patch. Try remove all source and build again. I include a image of my test in the wiki, and you may try out with the sof in de2_vga.zip. http://nioswiki.jot.com/wikihome/operating.../zimage_de2_vga (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/framebuffer/zimage_de2_vga) nano-X & nxview /home/ftp/rhino.jpg & The 8M memory on DE2 is very tight. So you should [NOT] add too many features/drivers in kernel , and user apps.
