12 years agoFPGA memory initialization and management
Hi, my design is using a cyclone IV on-chip memory. I have two questions (for the moment): - when configuring the memory with qsys, I don't really understand the data-width choice. If it's 32-bi...
12 years ago --- Quote Start --- I love to learn new things! --- Quote End --- Great! With FPGAs, there are plenty of opportunities. --- Quote Start --- 1. I do use the Eclipse ISE but I don't know how to use a debugger. Is there a tutorial or a document I could read to learn that? --- Quote End --- Altera has a "My First NIOS II Tutorial" that provides a walk-through of their Eclipse setup. --- Quote Start --- 2. I don't use an Avalon-MM bridge in Qsys. I've read papers about that but it seemed complicated and I preferred the self-made method to use a dual-port memory to access it both with software and with hardware. --- Quote End --- You can use self-made hardware, but its much more efficient if you create those self-made components as Qsys components and then wire them together in the Qsys GUI as this saves you having to create arbitration logic. Here some tutorials on using the JTAG interface to access custom logic; http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf --- Quote Start --- 3. I know Modelsim but I don't know how to do that. --- Quote End --- You need to learn this too. The best way to debug hardware issues is to trace the problem using SignalTap II and then reproduce that problem in simulation, and then debug in the simulator. --- Quote Start --- If one of the 3 options seems better for you, please tell me and surely I'll need your help to go further... --- Quote End --- You need to learn them all :) Cheers, Dave
