12 years agoFPGA memory initialization and management
Hi, my design is using a cyclone IV on-chip memory. I have two questions (for the moment): - when configuring the memory with qsys, I don't really understand the data-width choice. If it's 32-bi...
12 years agoAssuming you have your base address correct, try the following code;
# include <stdio.h>
# include "system.h"
int main()
int *pmem;
int i=0;
printf("Start!\n");
pmem=(int *)(0x80000000|(ONCHIP_MEMORY2_0_BASE));
for (i=0; i<15; i++)
printf("%u\n", *pmem++);
return 0;
The statement *pmem++ operates as follows; *pmem points to the 32-bit int, so your print statement prints out the value of the integer, and then the ++ increments the pointer by the size of the pointer, i.e., 32-bits. Your original code added i to a# define, so that would have only moved the pointer by a single byte. Cheers, Dave
