10 years agofpga load gives error code -2
We have created a custom board with a Cyclone V on it. The boot process works: We can go from preloader to u-boot to linux. But now I want to load something in the FPGA, and am trying to do from u-boot. However, I get stuck at error -2:SOCFPGA_CYCLONE5# mmc rescan
SOCFPGA_CYCLONE5# fatload mmc 0:2 0x2000000 switchbox_master.rbf
reading switchbox_master.rbf
7007204 bytes read in 393 ms (17 MiB/s)
SOCFPGA_CYCLONE5# fpga load 0 0x2000000 7007204
MSEL = 0
put FPGA in reset phase
FPGA is in reset phase
FPGA is out of reset phase
altera_load: Failed with error code -2 (I added some debug printout) According to https://rocketboards.org/foswiki/view/documentation/gsrd131programmingfpga Error code -2 means: The FPGA is not able to enter configuration phase after FPGA reset release request being made at FPGA Manager Any idea what can be wrong? Thanks, Michiel3 Replies
The data transfer yet happen which indicate the error not coming from the RBF.
A quick check on the FPGA config signal tie off against dev kit would be useful - Altera_Forum
We based our hardware design in the EBV SoCrates board. I looked at the nCONFIG pin, but could not see any difference. Is there some other pin? Or maybe a clock? I can't probe the pins at the moment, because I need our hardware guy for that, and he is away on holiday.
I now started the SoCrates board, and with the same rbf file, I get error -4. I think that is a seperate error, maybe related to the RBF format. - Altera_Forum
WE solved it now. It turned out that there was a short between CONF_DONE and nSTATUS. With that fixed, programming the FPGA works. Thanks for the suggestion to look there!
