21 years agoFPGA design & user program in EPCS?
I'd like to put both my FPGA design and my user code into an EPCS device. I've figured out how to put the FPGA design into the EPCS via JIC file but it's not entirely clear to me how the ...
21 years agoHi queisser,
> Will that cause the flash programmer to put my program into the EPCS? I always use the command line for this ... since I can roll it into a make target. Here's what I do: 1. create the application flash: $ elf2flash --epcs --base=0x0 --end = 0x7fffffff --flash=<whatever> --input=<your app elf> --outfile=<your app flash> 2. program the app to the epcs: $ nios2-flash-programer --epcs --input=<your app flash> --sof=<your pgmr sof> 3. create the flash file for your fpga sof: $ sof2flash --epcs --input=<fpga sof> --offset=0x0 --output=<fpga flash> 4. program ther fpga image: $ nios2-flash-programmer --epcs --input=<fpga flash> --sof=<your pgmr sof> --relocate > Can I create a JIC file that combines the FPGA and user code? Sorry ... never used JIC. > Will I still have to set the reset address to the EPCS? No. The epcs bootloader code just won't run. So you'll have to do the bootstrap in your own app. > Is it still possible to debug the program by loading the SOF file into RAM Yes. After loading the fpga configuration via jtag, everything will work as normal. If you happen to set your reset address to the epcs bootloader code, it will still grab the application from the epcs. Regards, --Scott
