13 years ago
FP Custom Instructions - exp() won't get any faster
Hi everybody.
I'm working on a design using Nios II/f that heavily relies on floating point math.
In Qsys I addedd Floating Point Hardware and I connected it to the Custom Instruction Master of the Nios II.
Apparently everything works.
My design is a Neural Network, so basically I have a loop of multiplication\addition and a loop of exponential calculus.
The first loop gets faster (about 10x), the second one doesen't change at all.
I tried to make a benchmark code, something like:
Performance Start
float a = 10;
for(i = 0; i < 1000; i++)
a = exp(a);
Performance End
And run it with and without the following pragmas:
# pragma no_custom_fadds# pragma no_custom_fsubs# pragma no_custom_fmuls# pragma no_custom_fdivs
The performance (about 6Mcycles if I remember correctly) doesen't change.
Hardware divide is enabled both in the Floating Point Hardware module and in the Nios II/f.
My doubt is that since i'm using qsys and not sopc i didn't find the "custom instructions" tab in the Nios II module where to specify the usage of FP Hardware, I assumed that in Qsys when you connect the module the FP hardware is always used unless de-activating pragmas are declared.
Maybe I was wrong here?
These are my includes:
# include <stdio.h># include "io.h"# include <sys/alt_alarm.h># include <altera_avalon_performance_counter.h># include "system.h"# include <math.h># include <float.h>
Thanks for the help! :)
    I 'm starter with Custom Instruction and the document for it is only Nios II Custom Instruction User Guide. It's not enought. Have you got more document or/and tutorial... for it?
    I've not seen any 'useful' docs ...
    The only ones I found just explained how to tick the boxes to enable the FP instructions.
    I've written a couple of combinatorial custom instructions, what I realised is that the nios doesn't really have an instruction 'decoder', just a great big mux that selects the required result. The A and B register values are read for every instruction, even tightly coupled data memory is read every clock - the value is discarded unless the instruction is a memory read for the required address range.
    So a combinatorial instuction creates a result value every clock that can be based on all 32bits of the instruction word and the the 32bit values read from the register file.
