14 years agofound.srec not detected
Hi, I was working on testing some things on the NIOS II on a DE2 board. It was working fine when I ran it as hardware. Suddenly it stopped working and this error message would flash in the cons...
12 years agoI just had the exact same problem with EDS in Quartus 13.1, but I also found out what was causing the problem.
I had just created another workspace, because I had two parallell development projects. So what I did was to remove both workspaces (i.e. removed the .metafile directory). Restarted Eclipse and choosed one of the directories and then I imported the project to the workspace and everything work as normal again. /BR Johan Karlsson
