20 years ago
Force Update of zImage
I was having problems getting the zImage to update properly when just experimentally adding/subtracting/modifying the romfs as in the Compile Hello example on the wiki.
My standard operation was:
make
make linux
make image
... then copy images/zImage to transfer to the NIOS II processor.
This mysteriously would not update all of the time (hardly ever).
So I found after a few days I could do this:
make clean
make linux_hwselect SYSPTF=insert your.ptf
make
make linux
make image
... the copy images/zImage to transfer to the NIOS II Processor.
This worked however it takes a while to do all of that. So I poked around the Makefile and on the wiki and finally stumbled upon some words of wisdom:
Whenever you update the ~/rootfs you have to compile the kernel and update the initramfs.
CHK usr/initramfs_list
CPIO usr/initramfs_data.cpio
GZIP usr/initramfs_data.cpio.gz
AS usr/initramfs_data.o
LD usr/built-in.o
If you didn't see the "CPIO" and "GZIP" in compile message, the initramfs is not updated. You will have to remove the file usr/initramfs_list in kernel dir, and compile again to force the update of initramfs.
This works. The key being the makefile checking to see if the initramfs_list file has been changed/modified/or missing.
In my case the file is in uClinux-dist-test/linux-2.6.x/usr/
So now the proper thing to do is:
rm -f linux-2.6.x/usr/initramfs_list
make (only if you want to recompile a user program or something)
make linux
make image
... copy the images/zImage elsewhere to use
I hope this helps someone out. I spent a couple of days on this.
Any helpful comments are appreciated.
