21 years agoForce Code/Data to specific locations
Hi Guys
The idea here is to have a self-test program running from internal memory, that then calls a "user program" in flash. For this to work, the entry point for the "user program" needs to be fixed. Is it possible to do this at compiler/assembler or linker level?1 Reply
Hi Jason,
> Is it possible to do this at compiler/assembler or linker level? You can do this with your linker script file. Regards, --Scott
