13 years agofopen("/dev/uart","w") returning NULL
Hey guys,
I'm attempting to communicate between my PC to the Nios II via RS-232. I've built up my system in SOPC and I'm using the eclipse tool to code in c. When I use the function fp = fopen("/dev/uart","w"), I always receive NULL. /dev/uart is the correct path according to my system.h file. Could you offer any advice? Thanks, Justin2 Replies
To fix the problem I unchecked "Lightweight device driver API" in the BSP editor.
--- Quote Start --- To fix the problem I unchecked "Lightweight device driver API" in the BSP editor. --- Quote End --- It worked for me too. Thanks!
