20 years agoFMAX Problem
Hello, I have a customboard design that uses the Cyclone EP1C20F324C7 device. Before I created my circuit board I created my design and let Quartus assign the pins, and I was able to achive an...
20 years ago --- Quote Start --- originally posted by banx@Aug 3 2006, 03:15 AM wouldn't it be great if you could tell quartus to keep trying until it reaches the required fmax. we could then just let it run overnight.
banx.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17375)
--- quote end ---
--- Quote End --- You're in luck... That's what DSE does (basically)! If you have never tried DSE, in Quartus II go to Tools -> Launch Design Space Explorer. Then, once it opens you can go to Options -> Stop flow when 0 failing paths are achieved Select several seeds, select how hard you want it to try, then let it run... and run... and run...
