20 years agoFMAX Problem
Hello, I have a customboard design that uses the Cyclone EP1C20F324C7 device. Before I created my circuit board I created my design and let Quartus assign the pins, and I was able to achive an...
20 years agoI guess that I was not very clear, I did let Quartus assign all the pins, and then in the assignment editor, I took the pins Quartus assigned and made those assignments, I then compiled again and got the results discussed above. The compilation was done with no change to the project. I was going to make a minor change however, I did not.
I was just wondering if using Logic Lock or one of the features that Quartus has, that I am unfamiliar with, would keep that original compilation and routing that was able to acheive the 80 MHZ. I do need to make a few minor changes to the project, and keep my FMAX close to 80 MHZ. Any ideas would be greatly appreciated. Maybe I am asking for too much! Thank-you for you help!! Brandon
