17 years agofltk change font size
i want to change the font and the fontsize in my app but not even the label or fonts-demo is working. is there a known bug about this?4 Replies
It works. Try the following (modified) demo app. Name it hello.cpp:
Compile it with: $ nios2-linux-uclibc-g++ -I/home/jars/nios2-linux/uClinux-dist/lib/fltk -c hello.cpp $ nios2-linux-uclibc-g++ hello.o /home/jars/nios2-linux/uClinux-dist/lib/fltk/lib/libfltk2.a /home/jars/nios2-linux/uClinux-dist/staging/usr/lib/libX11.a /home/jars/nios2-linux/uClinux-dist/user/microwin/src/lib/libnano-X.a -lpthread -o hello Remember to change the paths above to reflect your own system. You can have any font size by modifying the line: box->labelsize(36); Somethings to consider: - I never got to compile the FLTK demo apps by simply selecting the item in menuconfig; I think it's broken; - in /usr/fonts/truetype you should have your ttf fonts and a fonts.dir file:#include <fltk/Window.h># include <fltk/Widget.h># include <fltk/Font.h># include <fltk/run.h> using namespace fltk; int main(int argc, char **argv) { fltk::Font** FontsList; int FontsCount = fltk::list_fonts(FontsList); Window *window = new Window(300, 180); window->begin(); Widget *box = new Widget(20, 40, 260, 100, "Hello, World!"); box->labelfont(FontsList); box->labelsize(36); box->labeltype(SHADOW_LABEL); window->end(); window->show(argc, argv); return run(); }
Cheers, Ricardo./usr/fonts/truetype# ls DejaVuLGCSans.ttf DejaVuLGCSansCondensed-Bold.ttf dejavulgcsans.ttf dejavulgcsanscondensedbold.ttf fonts.dir /usr/fonts/truetype# cat fonts.dir 2 dejavulgcsanscondensedbold.ttf -dejavu-DejaVuLGCSans-medium-r-bold--0-0-0-0-p-0-iso8859-1 dejavulgcsans.ttf -dejavu-DejaVuLGCSans-medium-r-normal--0-0-0-0-p-0-iso8859-1 /usr/fonts/truetype# - Altera_Forum
$ nios2-linux-uclibc-g++ fltk_font.o /home/z125188/nios2-linux/uClinux-dist/lib/fltk/lib/libfltk2.a /home/z125188/nios2-linux/uClinux-dist/staging/usr/lib/libX11.a /home/z125188/nios2-linux/uClinux-dist/user/microwin/src/lib/libnano-X.a -lpthread -o fltk_font
/opt/nios2/usr/bin/nios2-linux-uclibc-ld.real: /home/z125188/nios2-linux/uClinux-dist/lib/fltk/lib/libfltk2.a(args.o): Relocations in generic ELF (EM: 3) /home/z125188/nios2-linux/uClinux-dist/lib/fltk/lib/libfltk2.a: could not read symbols: File in wrong format collect2: ld returned 1 exit status thats hopefully my last error. - Altera_Forum
Please don't use the lib/fltk, as it was broken. Please enable nxlib under microwin. Then it will build nxlib and fltk with demos.
- Hippo - Altera_Forum
lib/fltk is good if you do some changes in the makefile
but fltk2 keyboard works not correctly
