19 years agoFlashProgrammer has some problem!
Hi, everybody I'm newbie for niosII uClinux. I want NiosII boot from CFI Flash but I open NIOSII Command Shell can't find "cd arch/nios2nommu/boot" dir. Is my NIOSII Command shell has s...
19 years agoThe reset address in SOPC builder has nothing to do with uclinux.
If you want to boot uclinux from epcs, select epcs as reset address. If you want to boot from cfi flash, select cfi flash as reset address. First, you should make RS232 work using jtag download.
