19 years agoFlashProgrammer has some problem!
Hi, everybody I'm newbie for niosII uClinux. I want NiosII boot from CFI Flash but I open NIOSII Command Shell can't find "cd arch/nios2nommu/boot" dir. Is my NIOSII Command shell has s...
19 years ago --- Quote Start --- originally posted by hippo@Mar 22 2007, 09:39 PM did you test the new sof with serial uart and uclinux image using jtag download?
you should make them work before flash programming.
you sould not use nios2-terminal in this case,
use rs232 cable and a terminal emulater, such as hyper-terminal on windows, or minicom on linux.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22447)
--- quote end ---
--- Quote End --- Hi ,hippo I tested the new sof with serial uart and uClinux image using jtag download. I will use RS232 cable and Hyper-terminal run it,but it has not response. I will try out again. I have one question the "reset address" is "offset + address" in SOPC Builder? NiosQ
