19 years agoFlashProgrammer has some problem!
Hi, everybody I'm newbie for niosII uClinux. I want NiosII boot from CFI Flash but I open NIOSII Command Shell can't find "cd arch/nios2nommu/boot" dir. Is my NIOSII Command shell has s...
19 years agoDid you test the new sof with serial uart and uClinux image using jtag download?
You should make them work before flash programming. You sould not use nios2-terminal in this case, use RS232 cable and a terminal emulater, such as Hyper-terminal on Windows, or minicom on Linux.
