19 years agoFlashProgrammer has some problem!
Hi, everybody I'm newbie for niosII uClinux. I want NiosII boot from CFI Flash but I open NIOSII Command Shell can't find "cd arch/nios2nommu/boot" dir. Is my NIOSII Command shell has s...
19 years ago --- Quote Start --- originally posted by hippo@Feb 13 2007, 09:45 AM the zimage is loaded to sdram by a altera supplied boot loader. so there is nothing to do with kernel config.
since you want to boot from cfi flash, you must make sure the nios2 reset vector in sopc builder pointed to cfi flash. though it should be the default.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21517)
--- quote end ---
--- Quote End --- Hi,hippo Sorry for my question. If i program zImage on CFI Flash then how to display boot message on PC? Is use NiosII IDE or need other terminal? NiosQ
