19 years agoFlashProgrammer has some problem!
Hi, everybody I'm newbie for niosII uClinux. I want NiosII boot from CFI Flash but I open NIOSII Command Shell can't find "cd arch/nios2nommu/boot" dir. Is my NIOSII Command shell has s...
19 years ago --- Quote Start --- originally posted by hippo@Feb 12 2007, 02:59 AM the wiki page is changed. there is no need to "cd arch/nios2nommu/boot" now.
if you have tried from sdram, you should know where is the zimage. ~/uclinux-dist/images.
if you work on linux, open a normal terminal shell.
if you work on windows, you have to copy the zimage to a temp window dir. and work in that dir.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21442)
--- quote end ---
--- Quote End --- thx,hippo I saw it! I following your FLASH PROGRAMMER userguide but when I open Nios2 Command Shell and excute "nios2-configure-sof DE2_NET.sof", display follwoing error message: Searching for SOF file: in . DE2_NET.sof Error: Can't scan JTAG chain. Error code 87. I have try out nios2-configure-sof standard.sof ,but display same error message. How to slove it! I need your help! Thanks you again!
