19 years agoFlashProgrammer has some problem!
Hi, everybody I'm newbie for niosII uClinux. I want NiosII boot from CFI Flash but I open NIOSII Command Shell can't find "cd arch/nios2nommu/boot" dir. Is my NIOSII Command shell has s...
19 years agoThe wiki page is changed. There is no need to "cd arch/nios2nommu/boot" now.
If you have tried from sdram, you should know where is the zImage. ~/uClinux-dist/images. If you work on Linux, open a normal terminal shell. If you work on Windows, you have to copy the zImage to a temp window dir. And work in that dir.
