16 years agoFlash read causes two reads
I have the Stratix III development kit with the 512-Mbit Intel part on it. My command writes appear to be correct, looking at it with SignalTap. I write to the base address a command such as ...
16 years agoThe byte enables take the place of the low order address bits.
One of the slaves might be a 16 bit slave (connected via a bus width adapter), the other a 32 bit slave (with the high 16 data bits disconnected). Something like that would let you do the specific cycles needed for writing the flash memory (being very careful about the addresses).
