16 years agoFlash read causes two reads
I have the Stratix III development kit with the 512-Mbit Intel part on it. My command writes appear to be correct, looking at it with SignalTap. I write to the base address a command such as ...
16 years agono that is not completly correct.
there is a difference between normal memory access and IORD_16DIRECT as long as you use the IORD functions the byteenable indicated which bytes are needed. monitor via signaltap these two cycles and have a look at the byteenable i have such a module placed between avalon switch fabric and the external tristate bridge to get rid of these additional read cycles. in normal memory access it doesn't matter if you read 1byte, 2 byte or 4 byte, the data master will always read 4 bytes (32bit access)
