17 years agoFlash programming for DE2-70
Hello Friends, This is a common problem here in the forum. However, Ihaven't been able to make heads nor tails out of it. I'm trying to program the sof file by EPCS and the OS in the CFI Fla...
17 years agoHello all,
So I finally managed to boot from the CFI FLash. My mistakes were the following. 1) In hw_select I had to choose to boot from sdram, because I was choosing to boot from CFI Flash. 2) input instructions as follows.$ elf2flash --base=0x00000000 --end=0x007fffff --reset=0x0 --input=/home/pancho/nios2-linux/uClinux-dist/images/zImage --output=ext_flash.flash --boot=/opt/altera8.1/nios2eds/components/altera_nios2/boot_loader_cfi.srec
~/nios2-linux/uClinux-dist
$ nios2-flash-programmer --base=0x0 ext_flash.flash --go
Did the trick! Thank you Francisco
