17 years agoFlash programming for DE2-70
Hello Friends, This is a common problem here in the forum. However, Ihaven't been able to make heads nor tails out of it. I'm trying to program the sof file by EPCS and the OS in the CFI Fla...
17 years agoThe cfi flash of de2-70 net design uses 16 bits mode. Please change line 323 .width to 2.
linux-2.6/arch/nios2/kernel/config.c You may also change mtd map as 8MB flash at line 214, to, 0x400000, 0x400000, 0x400000, 0x000000 - Hippo
