20 years ago[Flash programmer]CycloneII and 29LV320 FLASH
We make a new NiosII board.There are EP2C5Q208 and MX29LV320, something else.
First, I got error when using flash programmer <div class='quotetop'>QUOTE </div> --- Quote Start --- [SOPC Builder]$ nios2-flash-programmer --input=output_file.flash --sof=f:/GU_Ni os/SW/myComponents/GU_Nios_2C5/system/GU_Nios_2C5.sof --base=0x01000000 WARNING: Default charset GBK not supported, using ISO-8859-1 instead Oct 27, 2005 4:56:01 PM - (??) nios2-flash-programmer: Launching Quartus Program mer to download: f:/GU_Nios/SW/myComponents/GU_Nios_2C5/system/GU_Nios_2C5.sof Pre-Reading 85KBytes of data from IC7: |----.----+----.----| ********************* (5.531 sec). Erasing 2 Sectors: |----.----+----.----| ********************* (2.125 sec). Writing 128KBytes : |----.----+----.----| *Unable to send write-packet @3674112 buffer-chunk write failed @3674112 erase-block write failed @3674112 write failed @3670016 Oct 27, 2005 4:56:21 PM - (??) nios2-flash-programmer: Unable to write to flash Oct 27, 2005 4:56:21 PM - (??) nios2-flash-programmer: Error: Write-operation fa iled on device. - exiting.[/b] --- Quote End --- Dose anybody else face the same error buffer-chunk BTY, I use this command to create target board$ mk_target_board --name=GU_Nios_2C5 --family=CycloneII --clock=50.0 --index=1 --buffer_size=40961 Reply
:confused: hi,
i need a help from this flash related things, we are using ep1s20 fpga with m29w640 application flash and with the same bus using for sram also. we are getting a problem as unable to write and read in that flash,but can be wrote and read in sram device. if u runned or worked with this flash,tel me how to access the flash with that fpga? and also how to do the write and read function in that?
