16 years agoFlash Programmer/AS Compatibility Problem?
Hello all,
I have been trying to learn how to use the NIOS II flash programmer recently. Essentially, what I want to be able to do is power up my board and have the FPGA properly configured and my C code running on the processor, right off the bat. I have a DE2 board with a Cyclone II FPGA, and I am using Quartus II version 9.1 and NIOS II IDE version 9.1. Here's the issue: If I use JTAG programming in Quartus to download the FPGA configuration to the board, the flash programmer in NIOS II IDE works just fine; I can download my code to the flash and run it. This would seem to indicate that there is nothing wrong with my system. If I use AS programming in Quartus instead, permanently storing the FPGA config. on the board, then when I try to use the flash programmer, I get the "There are no Nios II processors available which match the values specified" error. It doesn't matter whether I set up the system library to put the FPGA configuration data and the program data in the flash, or program data only; I get the same error. Does anyone know how I can fix this and get my board and program to boot up properly when I push the power button?5 Replies
Please read the Nios II flash Programming manual.
The image loaded into your FPGA is not the one you compiled your C code with. That's why you get the error. - Altera_Forum
But why is the image not the correct one? The IDE re-compiles my code every time I run the flash programmer; do I need to force it to recompile the system library as well? I've been through the manual but didn't see anything there to help me; as far as I can tell, I'm doing things right.
Further troubleshooting has convinced me that AS mode itself is the problem. Since I am using Quartus 9.1, I think I have that bug that prevents Quartus from properly generating some of the files needed for AS programming.
Update to QII 9.1 SP1
Yep, it works now. Thanks guys.
