21 years agoflash programmer
Does the Quartus flash programmer support to program raw binary images not created within eclipse IDE?
20 years agoHi Scott,
It sounds like you've got some experience with bin2flash. What are the pros & cons of using bin2flash vs. the zipfile system? And assuming you're using bin2flash, how does the Nios code know where to address the data? Is there some way to generate a header file with the base address, or something like that? thanks, Carol
