21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoHaving some problems getting u-boot up on a new board using the psyent source.
The symptom is that the u-boot banner and prompt show up, blinking cursor and all, but that's it. It wont accept or echo any chars. If I simply change the timer irq assignment in the mybd.h file to any other irq (even unassigned ones), then everything works except for the timer dependant functions; irqinfo shows no counting, ethernet stuff doesn't work. I am certain my address and irq assignments for the timer are correct. I have tested the timer and its irq with a separate piece of code and it is working. The same basic HW worked with a previous version of u-boot.
