21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoAhhh ... yes ... the jump table for u-boot mini-apps is (still) broken.
But passing the args should be correct -- I'll check on this. Thanks for the heads-up :-) Regards, --Scott
