21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoThanks Scott,
I found my main problem was those env variables. The 1S10_ES kit board (DK1S10?) must be very close to the PK1C20 configuration since most things are working. I have tested downloading images to this board using srec over serial, binary over serial and tftp (after installing the free solarwinds tftp server). I burned u-boot into the board using u-boot itself as in the USING directions. u-boot is pretty slick. It give you most of the features you would want from a boot monitor program. I have not been able to download and run the supplied hello world example, though. I used the "loads" and it did load, but a "go 800000" just seems to reboot u-boot. The example output is supposed to appear in the u-boot console window isnt it (not the jtag uart or debug port) ? It would be nice to have the following: A way to connect to the u-boot console over ethernet. As you mentioned, u-boot downloads are "pull" model, but if I could use telnet or ssh to get to the console, it would be exactly what I am looking for. A command that tells you where u-boot is executing from, and what system resources it is using. This is not very clear. A little more description for the configuration options. The custom board I need to port to has a different memory map and no SDRAM bank. It is not clear if I simply remove CFG options, and what option controls where u-boot relocates to.
