21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoHalfway thru writing my own ethernet downloader, I decided to check out the alternatives.
The Redboot docs indicate that no port exists for Nios boards. If someone has one, maybe they could post it. u-boot looks more promising. I was able to build for the "PK1C20" board configuration, and it can download and partially run on a 1S10_ES kit board I have. The console works but the ethernet does not, so there must be some critical differences between these boards. The image is smaller than I expected at ~100kB. This is probably smaller than my own downloader code, but with more features. I'd like to see it fully working on the 1S10 board before I spend my days porting u-boot to run on my custom board (The README is rather large). Does anyone know of more ports available or what I need to change to get it fully working on my kit board?
