21 years agoFlash Programmer Problems
Hi Everyone, I have built a target board in SOPC builder in order to program the flash memory on my board. The target board contains an EPCS controller and CFI flash controller (the actual board d...
21 years agoHi,
I tried the memtest firmware using /dev/epcs_controller as the device and the EPCS passed all the tests. I'm still wondering on what the problem would be? Is there a way to program firmware into flash without using the target board method. Is it possible to generate a file which you could download to the flash directly? Thanks a lot. -Sid
