12 years agoFlash programmer, Nios II Eclipse
Hi everyone!
I can't push on the select buttom's on the flash programmer. I kill many time to solve this problem, but all does not help for me. My OS is Win 7 x32 Please, help me. Thanks in advance. http://electronix.ru/forum/index.php?act=attach&type=post&id=820403 Replies
Please, did you solve your issue I have exactle the same one. A can paste the correct path but then also the Add.. button does not work :( Jan - Altera_Forum
Have you tried with keyboard : Tab, Tab, Tab to focus on the button and press Space to activate ?
--- Quote Start --- Have you tried with keyboard : Tab, Tab, Tab to focus on the button and press Space to activate ? --- Quote End --- It does not help. But on other PCs it works. I have discovered that also Open button does not work. It has to be connected with JAVA FileDialog or something. Becasue all other stuff works. :(
