14 years agoFlash Programmer Issues
I'm able to reset the Nios II and flash the EPSC with my .sof but not my .elf. Seems to be an issue resetting the Nios II processor the second time around. My system runs fine if I just download the ...
13 years agoHi DTPHawk,
Did you find any solution for this problem, I am struck with the same problem. I was suspecting the memory in EPCS device is not sufficient so the flash programmer uses the FPGA internal memory for some of the code. Thanks, laland
