21 years agoFlash programmer fails on custom board design
Hi I have a custom board design. My problem is that the flashprogrammer fails when trying to download to the flash, it fails with this message(Send (64) failed. Unable to synchronize with targe...
19 years ago --- Quote Start --- originally posted by celso@Jun 1 2005, 07:44 AM i had the same problem!
it only worked when i increased the clock frequency (originally was 50 mhz) to 75 mhz (using a pll).
good luck!
celso
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=7387)
--- quote end ---
--- Quote End --- I had the same problem too! But I can't fix it until now, can you describe the detailed process of making target_board. Can I turn off all of items in flash programmer, only turn on program flash memory with a file to program some other binary file into flash.? In my_target_board's sof. I am not sure the reset_n pin is right, and I don't how to use it in programming the flash. press it before I press the button program flash in flash programmer?
