21 years agoFlash programmer fails on custom board design
Hi I have a custom board design. My problem is that the flashprogrammer fails when trying to download to the flash, it fails with this message(Send (64) failed. Unable to synchronize with targe...
21 years agoThx for your answers Pod & Havard
<div class='quotetop'>QUOTE </div> --- Quote Start --- Just to be shure, you could also test the programming command manually: quartus_pgm --no_banner --mode=jtag --operation=p;MX_ATA_REV2.sof[/b] --- Quote End --- Ok tried the quartus_pgm. Have tried other ways to type it in also, but with same result.$ quartus_pgm --mode=JTAG --operation=p;MX_ATA_REV2.sof
Error: Programming option string "p" is illegal. Refer to --help for legal progr
amming option formats.
Usage:
quartus_pgm | -v]
quartus_pgm -c <cable name> filname.cdf --- If you want to use cdf file
quartus_pgm -c <cable name> -m <programming mode> -o <value> ---
If you want to use individual programming file(s)
quartus_pgm -l --- to display the list of available hardware
quartus_pgm -c <cable name> -a --- to display the list of devices connected to t
he cable
bash: MX_ATA_REV2.sof: command not found
/cygdrive/c/altera/kits/nios2/examples/mx_ata_rev2/system/software/memtest_ECT_R
EV2/Debug
$ <div class='quotetop'>QUOTE </div> --- Quote Start --- - There might be a problem if your programming design runs under 50MHz, I had the problem before. To avoid this, add a PLL to increase your Nios speed.[/b] --- Quote End --- The system runs at 100MHz <div class='quotetop'>QUOTE </div> --- Quote Start --- - The problem comes from your programming design pinout, but it seems to be a severe problem (not just a problem communicating with the flash, I think the Nios simply doesn't start). Maybe from the reset or the clock signals. Check your pin assign maybe.[/b] --- Quote End --- Will try and check them. Will report back on this. And thx again for using your time & energy on helping me out. Best regards Michael E
