21 years agoFlash programmer fails on custom board design
Hi I have a custom board design. My problem is that the flashprogrammer fails when trying to download to the flash, it fails with this message(Send (64) failed. Unable to synchronize with targe...
21 years agoHi
An update. This is what the flash programmer says when I run it in terminal mode. Looks like nada is getting written. Tryed measuring the /CS on the Flash. I see a couple of /CS on my scope right at the beginning, but then nothing happens(waiting for timeout an err from the flash programmer) Any ideas anyone???$ nios2-flash-programmer --base=0x0 --input=MX_ATA_REV2.flash --s
of=MX_ATA_REV2.sof --verbose --debug
May 30, 2005 2:13:37 PM - (FINE) nios2-flash-programmer: nios2-flash-programmer
starting
May 30, 2005 2:13:37 PM - (INFO) nios2-flash-programmer: args = --base=0x0 --inp
ut=MX_ATA_REV2.flash --sof=MX_ATA_REV2.sof --verbose --debug
May 30, 2005 2:13:37 PM - (INFO) nios2-flash-programmer: Attempting to read inpu
t-data from MX_ATA_REV2.flash
May 30, 2005 2:13:38 PM - (INFO) nios2-flash-programmer: Launching Quartus Progr
ammer to download:
MX_ATA_REV2.sof
May 30, 2005 2:13:39 PM - (FINE) nios2-flash-programmer: Quartus Pgm launched
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag --operation=p;MX_ATA_REV2.sof
Info: Using programming cable "USB-Blaster "
Info: Started Programmer operation at Mon May 30 14:13:42 2005
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020830DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Mon May 30 14:13:43 2005
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Processing ended: Mon May 30 14:13:43 2005
Info: Elapsed time: 00:00:04
May 30, 2005 2:13:43 PM - (FINE) nios2-flash-programmer: SOF programming done. e
xit code = 0x0000
Send (64) failed.
Unable to synchronize with target.
May 30, 2005 2:14:35 PM - (SEVERE) nios2-flash-programmer: Error opening target
hardware
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
/cygdrive/c/altera/kits/nios2/examples/mx_ata_rev2/system/software/memtest_ECT_R
EV2/Debug
$ Regards Michael E
