19 years agoflash programmer error
hello everyone:
I want to use flash programmer in NiodII IDE to program a file into flash. But the program process is not stable.Sometimes the process failed when it had programmed 61%,sometime the process failed when it had programmed 3%.. below is a segment of the error message: 000E0000 (53%): Programming 000F0000 (57%): Programming 00100000 (61%): Programming Program failed at offset 101504 Leaving target processor paused Does anyone have suggestions about this phenomenon? By the way, I use Byteblaster,and the version of quartus and nios II is 6.0. Thanks! 0quanquan02 Replies
Is even the hardware Image burnt in the EPCS?
please check the size of you software image and offset if your giving any. - Altera_Forum
What flash device are you using?
Jake
